TwinTurbo.NET: Nissan 300ZX forum - Re: Use a jumper wire to jump from your horn button to
Potacka
on August 11, 2017 at 12:48 PM
posted by -Grimm-
on August 11, 2017 at 11:24 AM
Thanks, that was my next move. From there I will be checking the two body grounds on the circuit also the two other connectors. I just got finished swapping in an air bag, no change.
Horn relay not pulling in Previous thread locked
Potacka
11:54:54 08/04/17
This is a rare issue but can happen. If the line running
jzack
20:38:27 08/04/17
Re: This is a rare issue but can happen. If the line running
Potacka
14:00:07 08/06/17
So if you jump the horn relay to ground, it works
-Grimm-
10:25:00 08/07/17
Re: So if you jump the horn relay to ground, it works
Potacka
11:32:21 08/07/17
Sounds like the relay coil is shot or the contact is
MixManMash
23:11:27 08/07/17
Re: Sounds like the relay coil is shot or the contact is
Potacka
23:24:26 08/07/17
Re: Re: Sounds like the relay coil is shot or the contact is
Potacka
23:25:33 08/07/17
Anyone else have any ideas?
Potacka
10:40:19 08/09/17
-Grimm-
11:24:12 08/11/17
Re: Use a jumper wire to jump from your horn button to -
Potacka
12:48:17 08/11/17
